climate-control specific:
1 - in-car temp. sensor reading; 2 - outside air temp. reading; 3 - left heater core temperature sensor; 4 - right heater core temp. sensor; 5 - evaporator temp. sensor; 6 - engine coolant temp. sensor; 7 - refrigerant pressure (in bar) – to convert to psi multiply by 14.7; 8 - refrigerant temperature at receiver/dryer; 10 - blower regulator control voltage (1 to 6 volts); 11 - emission sensor voltage (2.1 volts is about normal); 12 - sun sensor voltage (drops as light increases); 22 - vehicle speed (mph); 24 - battery voltage |
Laikas rodomas GMT +2. Dabartinis laikas yra 07:44. |
