-   C klasė (http://www.mb1.lt/forumdisplay.php?f=205)
-   -   Bendri klausimai apie C klasę (http://www.mb1.lt/showthread.php?t=6539)
Gintarys 2018-09-16 21:12
Gal dar kas "apšviestų" apie blueefficiency? Kiek žiūriu jie pas 204 ties 2010 atsirado. Cia kažkoks esminis patobulinimas? Jei reiktų rinktis su ar be blueefficiency ,tai kurį rinktumetės? Kaip suprantu jie "eina" su ta pačia 5G dėže?
Yzzo 2018-09-17 07:30
Info is wikipedios, jei moki angliskai, gali pasiskaityti.
These variants achieved better economy by weight reduction using a newly developed windscreen made of laminated glass from Maybach saloon, optimised noise-insulating firewall lining, using lightweight forged wheels with low rolling resistance tyres from Michelin, lightweight transmission; reducing drag coefficient to 0.25 via smooth under-body cladding, radiator grille shutter, sealing the joints between the hood and headlamps, as well as between the fender and headlamps, streamlined exterior mirrors housing, lowering the suspension by 15 millimeters, aerodynamically tuned wheels; servo pump shut-off in power steering system; new 6-speed manual transmission with newly developed final drive featuring further-improved anti friction bearings and forged differential gears, longer final-drive ratios (C 180 KOMPRESSOR, C 200 CDI); ECO Training mode cockpit; reduced engine displacement, optimising the combustion chamber, mixture formation and engine friction (C 180 KOMPRESSOR); direct injection with max 200 bar piezoelectric fuel injectors (C 350 CGI BlueEFFICIENCY).
Early models were introduced in Spring 2008, including C 180 KOMPRESSOR BlueEFFICIENCY, C 200 CDI BlueEFFICIENCY, C 350 CGI BlueEFFICIENCY.[30]
C 220 CDI BlueEFFICIENCY, C 250 CDI BlueEFFICIENCY, C 250 CGI BlueEFFICIENCY were introduced in 2009. C 250 CGI BlueEFFICIENCY includes direct injection. All 3 models include choice of sedan or station wagon.[31]
C 180 CGI BlueEFFICIENCY, C 200 CGI BlueEFFICIENCY, C 220 CDI BlueEFFICIENCY, C 250 CDI 4MATIC BlueEFFICIENCY were added in 2010, with C 250 CDI 4MATIC BlueEFFICIENCY and C 220 CDI BlueEFFICIENCY available in autumn 2010. All 4 models include choice of saloon or estate body. ECO start/stop function is included for C 180 CGI BlueEFFICIENCY, C 200 CGI BlueEFFICIENCY, C 220 CDI BlueEFFICIENCY. Direct petrol injection were added for C 180 CGI BlueEFFICIENCY, C 200 CGI BlueEFFICIENCY. C 250 CDI 4MATIC BlueEFFICIENCY includes Electronic Stability Program, traction system 4ETS.
Gintarys 2018-09-17 17:06
Viskas ok ,aš šitai skaičiau. Man daugiau įdomiau iš praktinės pusės informacija,kas pvz yra susidūręs/turi tokį ir t.t.
Čia tas pats OM646?
iMechanic 2018-09-18 19:50
Pradžioje rašė Gintarys (Post 505552)
Čia tas pats OM646?
OM651 jeigu analogo ieśkai.
Gintarys 2018-09-18 21:52
Pradžioje rašė iMechanic (Post 505635)
Tai pas prefl 204 BlueEFFICIENCY 2.2 CDI bus OM651? Jei ne BlueEFFICIENCY ,tada OM646?
Linius 2018-09-19 10:58
2004 2,2CDI, kas turi skydelyje uzsidegti, jei isijungia dpf regeneracija? Ar gali buti, kad pakaitinimo zvaku spirales simbolis?
vampyras 2018-09-19 11:00
Pradžioje rašė Linius (Post 505658)
niekas neuzsidega.
Linius 2018-09-19 11:28
Kaip daznai gali vykti regeneracija?
vampyras 2018-09-19 11:34
Pradžioje rašė Linius (Post 505665)
miesto rezimu du kartus, uzmiesti karta ant pilno kuro bako suvartojimo. cia grubus matmuo jaigu regeneracijos nebuvo nutraukiamos ir nera variklio kuro ismetimo skyriu gedimu.
P.s. va cia suskeliau ir patsai mastau ar kas nors ka nors supras. :D
Linius 2018-09-19 12:06
Viska supratau. Tik nemaniau, kad, taip daznai :)
Laikas rodomas GMT +2. Dabartinis laikas yra 06:42.
