Pas tave tikrai 225kw ?
nes siaip amerikos rinkai pagal metus ir rodo tik tokius C300: 170kw arba 185kw ------------- DE35 Three variants of the normally aspirated M276 DE 35 engine were produced in 2010-2017 with a displacement of 3.5 L (3,498 cc), bore and stroke of 92.9 mm × 86 mm (3.66 in × 3.39 in). Output of the first variant introduced on 2010 C350 CGI BlueEfficiency with 12.2:1 compression ratio is 215 kW (292 PS; 288 hp) at 6400 rpm with 365 N⋅m (269 lb⋅ft) of torque at 3000-5100 rpm[6]. Output of the second variant with 12.2:1 compression ratio is 225 kW (306 PS; 302 hp) at 6500 rpm with 370 N⋅m (273 lb⋅ft) of torque at 3500-5250 rpm. S350, CLS350, ML350, E350 and W204 C350 models received this higher output version from 2011 to 2015[4]. S400h hybrid model used this engine from 2012 to 2017 in combination with an electric motor in between the engine and torque converter. Detuned version of this engine was introduced on C300, and used also by E300 and S300 from model year 2013 to 2015, producing 248 hp (185 kW; 251 PS) and 251 lb⋅ft (340 N⋅m) of torque. ------------- https://mb1.ltd/files/1567540426_capture.png https://mb1.ltd/files/1567540426_capture1.png |
nemokamai negaliu. uzsisakyk silberyje CoC popierius, apie 80€ cia de. ten bus tsn ir hsn numeriai. pagal juos neimanoma sumaisyti kilovatu.
p.s. CoC popieriai kaip raktai generuojami tik savininkui esant. paspauti paziureti kaip jie atrodo nebuna. :) |
https://www.datamb.com/vin/7l9rK2e4gkvEbZeLm |
M013 ENGINE REDUCED PERFORMANCE Va ka raso wikipedia apie sumazintos galios versija: Detuned version of this engine was introduced on C300, and used also by E300 and S300 from model year 2013 to 2015, producing 248 hp (185 kW; 251 PS) and 251 lb⋅ft (340 N⋅m) of torque. Amerikoje modeliniai metai jei 2013 gali buti 2012 antra puse realus pagaminimas, ir tas irgi sutampa. Todel manau kad kara pralaimejai :vairuot: |
M276 V6-GASOLINE ENGINE M276 Pas tave 185 kw. Detuned version of this engine was introduced on C300, and used also by E300 and S300 from model year 2013 to 2015, producing 248 hp (185 kW; 251 PS) and 251 lb⋅ft (340 N⋅m) of torque. |
Irase 222kw
Eisiu skambint kaimunui, nes sustatem su jo glk350 m272 ir gavo antausi, reiskia pas ji like sveiku 170kw max :xx:
Laikas rodomas GMT +2. Dabartinis laikas yra 05:08. |
